Biggy5970
Feb 01, 2024Aspirant
Xr1000v2 geo filter ps5
I setup geofilter on ps5 with ping assist off and set it to USA cause there’s no games in Australia and it took 20 minutes to find a game and then it worked fine but tried today and just would find ga...
Netduma-Fraser
Feb 01, 2024NetDuma Partner
The purpose of the router isn't to get you servers that far away from you, as your ping will be high there is no guarantee you'll get those games. If you're playing CoD there are servers in Aus.
- Biggy5970Feb 01, 2024AspirantYeah understand that but there barely any warzone games and if there is it’s not a full lobby and was working no problem also nothing shows up on geo filter the server and people will pop up for a second then instantly go away
- Netduma-FraserFeb 02, 2024NetDuma PartnerTry this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works better.- Biggy5970Feb 03, 2024AspirantYeah been doing that I’ll find one game and then it wigs out and won’t let me find another till I close game and resync cloud could it be that the login duration ends on router login by the time I finish game
