Biggy5970
Feb 01, 2024Aspirant
Xr1000v2 geo filter ps5
I setup geofilter on ps5 with ping assist off and set it to USA cause there’s no games in Australia and it took 20 minutes to find a game and then it worked fine but tried today and just would find ga...
Biggy5970
Yeah understand that but there barely any warzone games and if there is it’s not a full lobby and was working no problem also nothing shows up on geo filter the server and people will pop up for a second then instantly go away
Netduma-Fraser
Feb 02, 2024NetDuma Partner
Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works better.
Wait 2 minutes
- Biggy5970Feb 03, 2024AspirantYeah been doing that I’ll find one game and then it wigs out and won’t let me find another till I close game and resync cloud could it be that the login duration ends on router login by the time I finish game
- Biggy5970Feb 04, 2024AspirantNevermind figured it out anybody trying all I did was setup geofilter before I turned on console and now is working fine
- Netduma-FraserFeb 04, 2024NetDuma PartnerGreat to hear you got it working, thanks for the update!
