lI_SimoHayha_Il
Feb 11, 2024Aspirant
XR1000V2 hangs twice a week
Hi all. I have a Nighthawk XR1000v2 router, with DUMAOS and firmware 1.1.1.16_2.1.25 which should be the latest version. About a month ago, it started to hang (no internet, no access via LAN/WiF...
Netduma-Fraser
Feb 11, 2024NetDuma Partner
That's hard to determine, do you notice any patterns about when it happens, e.g. really heavy internet usage, just changed a setting etc?
lI_SimoHayha_Il
No pattern, just normal usage, wfh, gaming, etc. Hasn't happen while downloading torrents, or streaming, or updates.
- Netduma-FraserFeb 11, 2024NetDuma PartnerHow often is it occurring, once a week, once a day, multiple times a day etc?
- lI_SimoHayha_IlFeb 11, 2024Aspirant
Between once per fortnight, and max twice a week.
- Netduma-FraserFeb 11, 2024NetDuma PartnerIn LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops it.
