DonnyMacT
Sep 09, 2024Initiate
Xr1000v2 promoted straight to admin account settings
I just done a factory reset on my xr1000v2 Pro Gaming Router and I get promoted straight to admin account settings without me signing in to the router with the default account credentials? Any help wo...
Sep 10, 2024Guru - Experienced User
How was the router setup after you reset it and setup from scratch?
Did you walk thru the setup wizard with a wired PC and web browser or use the Nighthawk app to set it up?
During most setups, you should encounter a process where it will ask you to input a new admin PW during the setup then get into the home page from there. Next log in should ask you for this new PW.
