DonnyMacT
Sep 09, 2024Initiate
Xr1000v2 promoted straight to admin account settings
I just done a factory reset on my xr1000v2 Pro Gaming Router and I get promoted straight to admin account settings without me signing in to the router with the default account credentials? Any help wo...
Netduma-Fraser
Sep 10, 2024NetDuma Partner
If you hadn't changed the default credentials during the wizard when you initially setup then your browser has probably saved them so you can sign in quickly.
- DonnyMacTSep 10, 2024InitiateOkay thanks for the rapid response Netduma-Fraser highly appreciated
- FURRYe38Sep 10, 2024Guru - Experienced User
Is this resolved for you then?
