zeth07
Jan 17, 2025Aspirant
XR1000v2 Random ping spikes at modem AND router, while wired?
I have been seeing ping spikes for months and have been going back and forth with visits from my ISP trying to "solve" the problem and nothing they do seems to actually fix it. They have replaced ...
zeth07
Jan 18, 2025Aspirant
I don't know if it will help identify the problem but I've attached a screenshot of the modem log. Not sure what I can tell them to point towards the problem if this is something they should already be seeing. Or at least a way to tell if it IS the coax cable in the walls but again that doesn't make sense if it works fine much later at night.
Netduma-Fraser
Jan 18, 2025NetDuma Partner
It's definitely worth sending that to them and seeing what they say, if they're unable to resolve then I would highly suggest changing IPs
