agqasem
Jan 23, 2021Aspirant
XR300 — Nighthawk Pro Gaming Router disconnects alot
hi my router keeps disconnecting throughtout the day for like 30 second every hour or so. i have tried factory resetting ( it made it worse imo). i have updated to the latest firmware and I feel lik...
Netduma-Liam
Jan 26, 2021NetDuma Partner
Sorry to hear you're having troubles!
Are both wired and wireless devices losing connection?
Are you able to access the XR300s interface when these drops occur?
Does the connection come back up on it's own? If not, what do you do to reconnect?
agqasem
Jan 26, 2021Aspirant
both wired and wireless disconnect
I can access the interface when it happens
the connect comes back on its own after 1 min or so
- Netduma-FraserJan 26, 2021NetDuma PartnerWhat is your exact physical setup? What is the XR connected to and what is the model of that modem/router?
- agqasemJan 27, 2021AspirantIts connected through a wire to a router provided by the Service provider. From doing my own research this seems to be a problem with netgear routers from a really long time ago with no actual solution.
- Netduma-LiamJan 27, 2021NetDuma Partner
OK great, do you know the model of the ISP modem/router?
We have seen similar issues to this in the past, unfortunately the solution seems to vary case-to-case so we still need to go through these troubleshooting steps to see how it can be resolved.
