Brvndo
Sep 30, 2020Follower
Xr300 - Crashes and restarts
I have had my Xr300 foir about 4 months - for the past month or 2. The router would randomly stop (not turn off) and restart. It wouild do this everyday, sometimes every 2nd day and at worst 2-3 times in one day. Have done the following to troubleshoot:
1. Checked power source (No issue)
2. Checked fibre box:
- Was replaced before i bought the modem
- Used an alternative modem to see if the same issue would occur - no issues
Seeing if anyone had the same issue and found a solution?
1 Reply
- Netduma-FraserNetDuma PartnerDo you have it plugged directly into a wall outlet or an extender? If the later please try directly into the wall and see if that helps.
