iAmazing
Mar 25, 2020Tutor
XR300 - Slow PS4 speeds
I got my new XR300 yestarday, after setup i was doing some tests and i found that my PS4 download and uploads speeds got slower... With my default smart router from my ISP i usually got 200 to 300mb...
Mar 25, 2020Guru - Experienced User
Are you still using your ISP's modem router? or what modem are you connecting to now?
have you went in and changed your QoS settins on the XR300 to refect your speeds? it runs initially but if it didn't get the fully speeds, then it'll be set lower.
iAmazing
Mar 25, 2020Tutor
plemans wrote:Are you still using your ISP's modem router? or what modem are you connecting to now?
Yes i still have my ISP router on because it needs to be on so the modem can send Internet(thats is what the ISP tech guys said) so i put it in Bridge mode and connect the XR300.
If i put my ps4 connected to my ISP router right now that is bridge the speeds go to normal, i change to XR300 and get slower.
Yes i customize QoS, and put my PS4 to 100%.
- plemansMar 25, 2020Guru - Experienced User
Yes i still have my ISP router on because it needs to be on so the modem can send Internet(thats is what the ISP tech guys said) so i put it in Bridge mode and connect the XR300.----not all bridge modes work properly. What model do you have?
Yes i customize QoS, and put my PS4 to 100%.-----if you can connect your ps4 and the router at the same time, it isn't functioning in bridge mode properly.
- iAmazingMar 25, 2020Tutor
plemans wrote:Yes i still have my ISP router on because it needs to be on so the modem can send Internet(thats is what the ISP tech guys said) so i put it in Bridge mode and connect the XR300.----not all bridge modes work properly. What model do you have?
I have a Technicolor tg789vac v2 that i put in bridge mode and that gives TV to the TV BOX.
How should bridge mode work properly?
In bridge mode/ modem only mode, it should only supply 1 public ip address. if you can hook more than 1 device to it, it usually means its doing some routing*. (unless your isp allows multiple public ip addresses, most dont)
You can try the XR300 in AP mode with bridge mode disabled and see how it runs. downside is you lose the benefits of the XR300 with its qos/gaming features. If everything works as it should, it means your ISP's gateway is causing the issues.
