hotpeppershrmp
Jul 03, 2022Aspirant
XR300 - Steam Problem
I'm playing Street Fighter 5 through Steam. No access points appear on the Recent Geofilter screen. It doesn't seem to be working properly at the moment. I set my PC to the Playstaion, and I have ...
- Jul 10, 2022When you get that message just wait 1 minute and then refresh the page. It's important that when you do the steps above that the game has been completely shutdown as well as steam, even from the System Tray. If it's still not working please provide a screenshot of the Geo-Filter page.
Netduma-Fraser
Jul 03, 2022NetDuma Partner
Disable fast search, you won't get good games with that, do this:
Quit the application/game/client completely, steam included, even from the system tray
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Wait 2 minutes
hotpeppershrmp
Jul 07, 2022Aspirant
Nothing still appears on the ping map.
Does resync a map mean a flush cloud?
When you use the flush cloud, you get a message that it takes too long, and nothing changes.
- Netduma-LiamJul 07, 2022NetDuma Partner
Yes, that's fine it should still have flushed.
When adding the PC to geo-filter, did you select "Choose manually" instead of picking a specific service?
If not, do that and report back.
If that hasn't worked, after flushing the cloud, can you go to System Information and check if there's any entries in the logs that pertain to the cloud flush?
- hotpeppershrmpJul 09, 2022Aspirant
With the flush cloud, "The work is taking longer than expected. Please wait a moment before using this R-App" message will be displayed
There seems to be nothing related in the log.
- Netduma-FraserJul 10, 2022NetDuma PartnerWhen you get that message just wait 1 minute and then refresh the page. It's important that when you do the steps above that the game has been completely shutdown as well as steam, even from the System Tray. If it's still not working please provide a screenshot of the Geo-Filter page.
