hotpeppershrmp
Jul 03, 2022Aspirant
XR300 - Steam Problem
I'm playing Street Fighter 5 through Steam. No access points appear on the Recent Geofilter screen. It doesn't seem to be working properly at the moment. I set my PC to the Playstaion, and I have ...
- Jul 10, 2022When you get that message just wait 1 minute and then refresh the page. It's important that when you do the steps above that the game has been completely shutdown as well as steam, even from the System Tray. If it's still not working please provide a screenshot of the Geo-Filter page.
hotpeppershrmp
Jul 07, 2022Aspirant
Nothing still appears on the ping map.
Does resync a map mean a flush cloud?
When you use the flush cloud, you get a message that it takes too long, and nothing changes.
Netduma-Liam
Jul 07, 2022NetDuma Partner
Yes, that's fine it should still have flushed.
When adding the PC to geo-filter, did you select "Choose manually" instead of picking a specific service?
If not, do that and report back.
If that hasn't worked, after flushing the cloud, can you go to System Information and check if there's any entries in the logs that pertain to the cloud flush?
