Jamie2002uk
Dec 14, 2020Aspirant
XR300 + QoS + Media Streaming on Samsung SmartTV
Good evening all I have just purchased a XR300 with the latest firmware on and set everything up without a problem, just got PS5 and thought I'd get a gaming router aswell. Also have 3 boys that us...
- Dec 31, 2020Thanks for the update, I don't think there is anything else I can suggest at the moment unfortunately. It would be best to see whether it works on the beta, then if it doesn't we can take a look as we'll be actively developing for that version so I'd suggest disabling QoS fully for the moment.
You won't be notified but keep checking here to see when it becomes available: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
Jamie2002uk
Dec 15, 2020Aspirant
Good afternoon
I'm glad DumaOS 3.0 is coming to the XR300 and really do like the work you've done for us gamers. Best router I've had running some amazing amazing software. I've been looking at the R2 and maybe after Christmas I might treat myself.
I will upload a screenshot of my QoS configuration when I get home as I can't seem to get anywhere access working at the moment but no that bothered about that.
I do have share excess bandwidth enabled though
Thanks for the quick reply also 👍
Netduma-Liam
Dec 15, 2020NetDuma Partner
Hey,
Thanks for you feedback, we're glad you're enjoying DumaOS, it's just going to keep getting better and better!
I'll wait to see your config and we'll go from there!
- Jamie2002ukDec 18, 2020Aspirant
Good Afternoon
I have attached a screenshot of my QoS config and i do have Share excess bandwidth enabled.
On my Galaxy S10 the ITV hub will work and stream stuff but it does just seem to be the TV that doesnt want to. I have tried prioritising the TV with upload/download and enabling all ports to the TV
If their is anything else you would like me to try or detailed event log anywhere jsut let me know. I know my old router had DD-WRT running on it with a hidden event log URL but im new to DumaOS.
Thanks again and hope all the DumaOS team have a great christmas
- Netduma-FraserDec 18, 2020NetDuma PartnerThank you for the information. In Settings > WAN could you change NAT to open please and see if that helps at all?
- Jamie2002ukDec 18, 2020AspirantEvening
I had already changed this from secured to open. And I've left it on open, just test with QoS enabled and not working
