Jamie2002uk
Dec 14, 2020Aspirant
XR300 + QoS + Media Streaming on Samsung SmartTV
Good evening all I have just purchased a XR300 with the latest firmware on and set everything up without a problem, just got PS5 and thought I'd get a gaming router aswell. Also have 3 boys that us...
- Dec 31, 2020Thanks for the update, I don't think there is anything else I can suggest at the moment unfortunately. It would be best to see whether it works on the beta, then if it doesn't we can take a look as we'll be actively developing for that version so I'd suggest disabling QoS fully for the moment.
You won't be notified but keep checking here to see when it becomes available: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
Jamie2002uk
Dec 31, 2020Aspirant
Afternoon
I tried this but with no joy, I deleted the device and it actually come back as "Computer" so didn't need to change it but still ITV player still doesn't work. It does seem to be limiting tge traffic because with QoS switched on the channel icons take a little while to load up but when QoS is switched off they are instant I actually didn't know they was pulled from the Internet.
Just a side note, will I get notified when DumaOS 3.0 is available for my router?
Thanks
Thanks
Netduma-Fraser
Dec 31, 2020NetDuma Partner
- Jamie2002ukDec 31, 2020AspirantThank you for the help anyway and I will keep checking the link.
Have a happy new year to the DumaOS Team, hopefully next year will be a better one
Thanks again
Jay - Netduma-FraserJan 01, 2021NetDuma PartnerYou're very welcome and thank you, Happy New Year to you too Jay!
