hotchili
Nov 28, 2020Follower
XR300 2.4 network dropping out
Hey, So for the last month or so I’ve been having a lot of problems with the 2.4 GHz wifi network. My 5 GHz is all working fine, but anything connected via 2.4 ie Nest Cam, Echo, Music Streamer are...
Netduma-Fraser
Nov 28, 2020NetDuma Partner
Give those devices reserved IP addresses in LAN Settings and see if that helps. Do you see any entries in the log file when it happens?
