akale90's avatar
akale90
XR300 Awful wifi signal
Hello,
Just bought an XR300 router as the wifi signal from my current one is shocking, so have turned that into a modem (my ISP's kit) and setup the xr300 - it did cause me alot of issues to setup, but once i did it was perfect. However, the second I leave the room and go to any other part of the house (anywhere downstairs, and any room upstairs as well) the signal drops completely, on both 2.4 and 5ghz networks. I have changed wifi channels, disabled the 5ghz network to see if that made any difference and nothing. I am losing my hair over this as I spent alot of money so we would have guaranteed wifi in every room, plus not much time to play around with it as I'm working odd hours. Any advice why this is? Is it a dodgy router? Or is the wifi strength/signal not brilliant on this router?
Thank you
  • FURRYe38's avatar
    What building materials is the home made of?
    Where in the home is the router place? Main floor centrally is recommended.
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM.
    Is Smart Connect enabled?
    • akale90's avatar
      akale90
      Thanks for the reply.
      Couldnt tell you the size of the house as I have just moved in there, and made of bricks.
      Its placed in the lounge currently due to where the modem is and I have manually set channels after scanning the nearby neighbours channels. Both 2.4 and 5ghz are using unused channels.
      I dont believe there is a smart connect option for this model (could be wrong) and beamforming is enabled.
      My ISP is Virgin Media in the UK with a Superhub 3 - I did check first and people are using the XR300 with this model and all okay.
      I just fail to see how the wifi range on this model can actually be worse than what there was before!!
      • FURRYe38's avatar
        "I have just moved in there, and made of bricks." This maybe one reason why the wifi isn't traveling well in the home. Brick and mortor or concrete and rebar will cause wife signal propagation to not go a far. You may need an additional wifi extender to help with this. Maybe two depending upon size of the home. Size of the home is important. Larger the size will need an additional extender.
