tomjacob
Apr 05, 2020Aspirant
XR300 cannot replace ISP modem / router
Hi there, I have an XR300, Factory Reset, updated firmware. I am in New Zealand and trying to user the XR300 to replace the router provided by ISP. I followed the steps from ISP, as per this page. ...
Netduma-Fraser
Apr 05, 2020NetDuma Partner
The XR300 is only a router which mean it does need a router or modem to plug into to get internet, unless you have an ONT you can connect it to. How is the ISP router connected to the internet e.g. coax cable
tomjacob
Apr 06, 2020Aspirant
Hi,
I have got the ONT. The XR300 was connected to the same port on the ONT as the ISP router was connected.
- Netduma-FraserApr 07, 2020NetDuma PartnerSo have you set the VLAN Settings as well otherwise you won't get a connection without them.
- tomjacobApr 07, 2020Aspirant
Hi,
Yes. I did set the VLAN. In my original post, I have mentioned a link from the recommended settings from ISP. I did conifigure all the settings mentioned in that, which inlcudes VLAN
- Netduma-FraserApr 07, 2020NetDuma PartnerWith VLAN did you edit the existing internet rule or make a new one? If you made a new one edit the existing one and see if that helps.
