tomjacob
Apr 05, 2020Aspirant
XR300 cannot replace ISP modem / router
Hi there, I have an XR300, Factory Reset, updated firmware. I am in New Zealand and trying to user the XR300 to replace the router provided by ISP. I followed the steps from ISP, as per this page. ...
JLBaker
May 01, 2020Aspirant
Hi there.
We are having the same issues. We are with Vodafone and have a fibre connection. Bought the XR300 today as Vodafone's stock modem is so slow and useless. We are connecting the router directly to the fibre box - ethernet cable from the GEN1 port on fibre box directly into the yellow WAN port on the router. All the LED lights are white, except the internet access one which is orange. Vodafone states our fibre connection is working perfectly.
We simply cant seem to set it up,and neither of us are tech wizards.
Did you manage to sort yours out?
Netduma-Fraser
May 01, 2020NetDuma Partner
Sorry to hear you're having this issue as well, have you followed all the suggestions thus far to see if that resolves it?
