SandokanS
Apr 20, 2021Aspirant
XR300 cant get past bandwidth setup
I'm trying to access DumaOS, I just bought xr300 and I cant get it to work. I set it up like an access point with a help of auto installation as I already have a Nighthawk 7800 as my main router and ...
SandokanS
- Netduma-FraserApr 20, 2021NetDuma PartnerUsing the router in AP mode means that DumaOS features including the Geo-Filter are disabled. This is likely why you're having trouble setting up as well as the router doesn't need to know your bandwidth speeds in AP mode. Set it up as a router and it should work.
- SandokanSApr 20, 2021Aspirant
Hi thanks for your reply, can I set it as a bridge? I already have a main router.
Thanks
- Netduma-FraserApr 20, 2021NetDuma PartnerNo, it wouldn't work as a bridge as it would have to be bridged to something. You can have it set as the normal router mode, put the XR300 WAN IP in the DMZ of the Nighthawk and that will prevent a double NAT for the device you use with the Geo-Filter. Can also turn of the XR WiFi if you prefer.
