CBTStoii
Mar 05, 2022Follower
XR300 CFE BIN
i flashed new netgear firmware but it was the wrong file and has now rewritten my cfe, would someone please be able to send me their cfe file so i can fix my router please, i think this is the link fo...
michaelkenward
Mar 06, 2022Guru - Experienced User
CBTStoii wrote:
i flashed new netgear firmware but it was the wrong file ....
Netgear's standard update process makes it almost impossible to apply the wrong firmware to a device.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
