yourKnightmare
Feb 09, 2022Tutor
XR300 connection issues over ethernet
Hello, I am new to this forum, but I felt the need to seek out some help with my router. I am currently with AT&T Fiber via U-verse. I have a Pace 5268AC with my XR300 router(DMZ+, what I read was th...
Feb 09, 2022Guru - Experienced User
One of the few times its worth it to post in the correct forum for your device as the DumaOS guys are super responsive and helpful.
- yourKnightmareFeb 09, 2022Tutor
hey, I really appreciate you responding and pointing me in the right direction. figured this might have been the right area. but thank you
- Netduma-FraserFeb 09, 2022NetDuma PartnerFirst thing to do would be to disable the Geo-Filter and see if it occurs as it's most likely the cause
- yourKnightmareFeb 10, 2022Tutor
Geo-Filtering was never on.
