yourKnightmare
Feb 09, 2022Tutor
XR300 connection issues over ethernet
Hello, I am new to this forum, but I felt the need to seek out some help with my router. I am currently with AT&T Fiber via U-verse. I have a Pace 5268AC with my XR300 router(DMZ+, what I read was th...
Feb 09, 2022Guru - Experienced User
One of the few times its worth it to post in the correct forum for your device as the DumaOS guys are super responsive and helpful.
yourKnightmare
Feb 09, 2022Tutor
hey, I really appreciate you responding and pointing me in the right direction. figured this might have been the right area. but thank you
- Netduma-FraserFeb 09, 2022NetDuma PartnerFirst thing to do would be to disable the Geo-Filter and see if it occurs as it's most likely the cause
- yourKnightmareFeb 10, 2022Tutor
Geo-Filtering was never on.
- Netduma-FraserFeb 10, 2022NetDuma PartnerLet's continue in the other topic otherwise it will get confusing:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR300-connection-issues-over-ethernet/m-p/2194771#M28704
