yourKnightmare
Feb 09, 2022Tutor
XR300 connection issues over ethernet
Hello, I am new to this forum, but I felt the need to seek out some help with my router. I am currently with AT&T Fiber via U-verse. I have a Pace 5268AC with my XR300 router(DMZ+, what I read was th...
yourKnightmare
Feb 09, 2022Tutor
hey, I really appreciate you responding and pointing me in the right direction. figured this might have been the right area. but thank you
Netduma-Fraser
Feb 09, 2022NetDuma Partner
First thing to do would be to disable the Geo-Filter and see if it occurs as it's most likely the cause
- yourKnightmareFeb 10, 2022Tutor
Geo-Filtering was never on.
- Netduma-FraserFeb 10, 2022NetDuma PartnerLet's continue in the other topic otherwise it will get confusing:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR300-connection-issues-over-ethernet/m-p/2194771#M28704
