yourKnightmare
Feb 09, 2022Tutor
XR300 connection issues over ethernet
Hello, I am new to this forum, but I felt the need to seek out some help with my router. I am currently with AT&T Fiber via U-verse. I have a Pace 5268AC with my XR300 router(DMZ+, what I read was th...
yourKnightmare
Feb 09, 2022Tutor
I actually do not have geo-filtering on.
Netduma-Liam
Feb 10, 2022NetDuma Partner
Do you have an Open NAT reading in game before you have these issues? Could you please verify that the IP in the DMZ of your modem still matches the WAN IP of the XR300? If you didn't reserve it, it could've changed and could cause you issues.
- yourKnightmareFeb 10, 2022Tutor
I used to have an Open NAT when I played Call of Duty but I recently got Moderate. and now I can't get a reading in any CoD title when plugged into the router. it won't let me load up I will just get a disconnection before I can even get into the game. and as far as the IP and WAN IP I am not sure how to check to see if they match and what not. if you could point me in the right direction for that, I would appreciate it. thank you.
- Netduma-FraserFeb 10, 2022NetDuma PartnerCheck the WAN IP shown on the System Information page on the XR, then check the IP that is on the DMZ on the pace, do they match? If not put in the WAN IP from the System Information page in and see if the issue still occurs.
they match
