AbaloneBrush
Dec 30, 2020Aspirant
XR300 could not set up vpn in openvpn
setup the dns and vpn then download the zip from <For Smart Phone> unzip the the file (4 files in it) take the client3.ovpn and email to my iphone and open it in openvpn then the app error : "F...
Netduma-Fraser
Jan 01, 2021NetDuma Partner
I just tried it on my router and with the app and it worked fine. Did you extract the .ovpn file out of the zip folder before you sent it to your phone? Are you using the OpenVPN Connect app or another one?
AbaloneBrush
Jan 01, 2021Aspirant
I extract the .opvn from the zip (using winrar)
but what about the other file? should i do anything about them?
more info about the system
| Firmware version | XR300 1.0.3.50_10.3.36 |
OpenVPN ios ver 3.2.2(3507)
- Netduma-FraserJan 01, 2021NetDuma PartnerAll I did was import the .ovpn file into the app and it worked.
