bebo131
Mar 13, 2021Aspirant
XR300 Disconnects every 2 hours
My router XR300 keeps disconnecting/dropping me from any game that needs a constant connection like Call of Duty Modern warfare or Warzone every 2 hours consistently. I don't get dropped from every o...
Netduma-Fraser
Mar 16, 2021NetDuma Partner
Does it restore the connection immediately after the drop? Are you using the Geo-Filter? If so disable that, does the issue continue?
- bebo131Mar 16, 2021Aspirant
i dont know how to disable the Geo-Filter i m going to add some pictures this just happened today after 2 hours it kick me out, live stream was running and other online applications as well i contact battle.net and there is no problems with the game in my pc or the servers.The problem is the router that after 2 hours kicks me out of the online gaming
- Netduma-LiamMar 17, 2021NetDuma Partner
In your browser, go to 192.168.1.1 or routerlogin.net and login to the DumaOS interface. In here you can go to Geo-filter and select 'Specatator mode' for you PC.
- FaiixMar 18, 2021Aspirant
i am having exact problem do you managed to fix it ?
i tried:
Upnp on and off
IPv6 on and
Qos on and off
geo- fillter on and off
still getting disconncted
- Netduma-FraserMar 18, 2021NetDuma PartnerFaiix What is your NAT type? Are you playing over WiFi or ethernet?
