bebo131
Mar 14, 2021Aspirant
XR300 Disconnects every 2 hours
My router XR300 keeps disconnecting/dropping me from any game that needs a constant connection like Call of Duty Modern warfare or Warzone every 2 hours consistently. I don't get dropped from every o...
bebo131
for some reason is only with warzone/ modern warfare. Everytime this happens my internet still works and others stuff keeps running just fine. This is the second same router that i get and the problem is the router. If i plug the ethernet directly to the PC from the Modem i dont have any problems i can play for many hours there must be a settings that i need to fix but i dont know what it is. My pc have everything updated plus mu ISP gave me a new modem additional to that i did some troubleshootings here on my pc and ebverything is ok. any solution for this problem
Netduma-Fraser
Mar 14, 2021NetDuma Partner
Can you disable the Geo-Filter please and see whether the issue continues?
- bebo131Mar 14, 2021Aspirant
how i can disable the geo-filter i dont have any devices on it?? i only have the radar placed in the state i live since there is a close server for call of duty?
- Netduma-FraserMar 14, 2021NetDuma PartnerYou didn't mention whether it was enabled or not, when it next happens can you take a look at the log file on the System Information please and see if there are any entries at that time and post them here?
