bebo131
Mar 14, 2021Aspirant
XR300 Disconnects every 2 hours
My router XR300 keeps disconnecting/dropping me from any game that needs a constant connection like Call of Duty Modern warfare or Warzone every 2 hours consistently. I don't get dropped from every o...
Gamer252
Jul 21, 2021Aspirant
I also own the xr300 and I also have same issues. When playing a game like Warzone or halo it just disconnect mid game. Very frustrating. I was hoping they would have DumaOS 3.0 available for the xr300 by now but sadly it's still not.
I have my pc connected with an ethernet connection. Turning geofilter off makes no difference.
- Netduma-LiamJul 22, 2021NetDuma Partner
Gamer252 Is it just the game that's disconnecting or is the entire network losing connectivity?
What firmware version are you currently running.
- Gamer252Jul 22, 2021Aspirant
The game just disconnects but the internet (web browsing etc) works fine. I don't know which firmware its running because I went back to my old router but I did do a firmware update not that long ago (less than 1 month) so it's probably the current version.
It would be nice if you guys can allow the Duma 3.0 beta for xr300 routers. This way we can test to see if it's a hardware or software issue.
- Netduma-LiamJul 23, 2021NetDuma Partner
Gamer252 OK you're likely on the latest then. I'd be interested to see if you still get the disconnections from game with filtering mode disabled. Next time you're using the XR300 give that a go and let us know if it continues.
