dvnarellano
Mar 28, 2022Aspirant
XR300 Disconnects From Online Games Exactly at 2 hours
Nighthawk Pro Gaming Router XR300\ Firmware is up to date Modem: Netgear CM1000 PC and PS5 Hello, I am reaching out in hopes that someone can propose a solution for my problem. Anytime I a...
Netduma-Liam
Mar 29, 2022NetDuma Partner
When you disconnect, is it just the gaming device that loses connection, or do all devices on the network lose connection?
If you're not playing any games, does it remain connected consistently?
Are you currently using Geo-filter or QoS? If so, could you please share how you've currently got these configured.
dvnarellano
Mar 29, 2022Aspirant
1) When the disconnection occurs, I believe its only the gaming device that loses connection. And it is very quick to reconnect. When it happens, I am still able to chat on discord and PS5 party chat, so I am thinking there might be a momentary disconnect which kicks me from the online game and then it reestablished connection almost immediately.
2) I haven't noticed, but with the disconnections and reconnections being so fast, I don't think I would even notice if I am simply web browsing. I will say that I have never had issues streaming content on my TV. For instance, movies and shows over a two hours period, and I have never been disconnected.
3) I don't believe I am using either QoS or geo-filter at this time. I have tried messing with them in the past to find a remedy, which came to no avail. I think geo-filter is off at the moment, as I have no devices added for it to apply to. As for QoS, I have also tried various options. Currently I have anti-bufferbloat set to "always" and previously it was set to "never" Both options resulted in disconnects. My bandwidth allocation is currently set to even across all devices. I have even tried setting 100% allocation to whichever gaming device I was using at the time, and this did not fix the problem, so I changed it back to being even. I don't have any devices set up for Traffic Prioritization, but have previously tried adding both my PS5 and PC, which did not fix the issue either.
Thank you for your help. Please let me know if there are other options available to me, thank you!
- Netduma-FraserMar 29, 2022NetDuma PartnerThanks for all the information, it's very helpful! Is it any particular games you notice it happen in or is it any game? Could you provide the log from the System Information page when the issue happens and tell us the time it happened? Hopefully there will be an entry in there that we can attribute to the issue
- dvnarellanoMar 29, 2022Aspirant
1) I only play two games. One is warzone on PC and the other is FIFA on my PS5. This issue is consistent on both devices and both games.
2) Here is the recent logs. I started playing at 1306 and got disconnected at 1504
[Remote login] from source , Tuesday, Mar 29,2022 15:07:24
[Remote login] from source , Tuesday, Mar 29,2022 15:06:52
[Remote login] from source , Tuesday, Mar 29,2022 15:06:42
[DHCP IP: (192.168.1.10)] to MAC address AE:08:7D:F4:5B:AC, Tuesday, Mar 29,2022 15:04:28
[LAN access from remote] from 24.117.24.209:3074 to 192.168.1.7:3074, Tuesday, Mar 29,2022 13:06:21
[LAN access from remote] from 185.34.107.129:3075 to 192.168.1.7:3074, Tuesday, Mar 29,2022 13:01:39
[Time synchronized with NTP server] Tuesday, Mar 29,2022 12:44:32
[Internet connected] IP address: 68.7.43.253, Tuesday, Mar 29,2022 12:44:32
[DHCP IP: (192.168.1.2)] to MAC address 58:D9:D5:E7:1C:BD, Tuesday, Mar 29,2022 12:29:17
[Remote login] from source , Tuesday, Mar 29,2022 12:09:20
[Remote login] from source , Tuesday, Mar 29,2022 12:08:49
[Remote login] from source , Tuesday, Mar 29,2022 12:08:18
[Remote login] from source , Tuesday, Mar 29,2022 12:07:45
[Remote login] from source , Tuesday, Mar 29,2022 12:07:31
[DHCP IP: (192.168.1.9)] to MAC address E2:CF:97:AC:81:8B, Tuesday, Mar 29,2022 12:01:07
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Mar 29,2022 10:39:24
[DHCP IP: (192.168.1.6)] to MAC address 26:12:FD:8D:99:1A, Tuesday, Mar 29,2022 10:31:19
[DHCP IP: (192.168.1.8)] to MAC address D6:8A:D1:07:69:72, Tuesday, Mar 29,2022 10:24:33
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Mar 29,2022 10:16:58
[LAN access from remote] from 185.34.107.129:3075 to 192.168.1.7:3074, Tuesday, Mar 29,2022 10:14:10
[UPnP set event: Public_UPNP_C3] from source 192.168.1.7, Tuesday, Mar 29,2022 10:14:07
[Remote login] from source , Tuesday, Mar 29,2022 10:08:02
[Remote login] from source , Tuesday, Mar 29,2022 10:01:42
[Remote login] from source , Tuesday, Mar 29,2022 10:01:12
[Remote login] from source , Tuesday, Mar 29,2022 10:01:00
[Remote login] from source , Tuesday, Mar 29,2022 10:00:50
[DHCP IP: (192.168.1.7)] to MAC address 18:C0:4D:0D:80:77, Tuesday, Mar 29,2022 10:00:13
[DHCP IP: (192.168.1.4)] to MAC address A0:78:17:88:E4:0C, Tuesday, Mar 29,2022 09:36:50
[DHCP IP: (192.168.1.6)] to MAC address 26:12:FD:8D:99:1A, Tuesday, Mar 29,2022 08:48:07
[DHCP IP: (192.168.1.5)] to MAC address D6:8A:D1:07:69:72, Tuesday, Mar 29,2022 00:45:31
[DHCP IP: (192.168.1.4)] to MAC address A0:78:17:88:E4:0C, Tuesday, Mar 29,2022 00:45:07
[Internet connected] IP address: 68.7.43.253, Tuesday, Mar 29,2022 00:44:32
[Time synchronized with NTP server] Tuesday, Mar 29,2022 00:44:31
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Aug 08,2023 02:57:52
[DHCP IP: (192.168.1.2)] to MAC address 58:D9:D5:E7:1C:BD, Tuesday, Aug 08,2023 02:57:10
[Internet disconnected] Tuesday, Aug 08,2023 02:57:09
[Initialized, firmware version: V1.0.3.72_10.3.55] Tuesday, Aug 08,2023 02:57:03- Netduma-LiamMar 30, 2022NetDuma Partner
Could you please go to the XR Settings -> Setup -> LAN Setup and change the DHCP starting IP address to 192.168.1.100.
Then, add IP address reservations for both your PC and your PS5. Make sure you reserve them IP addresses that are outside of the DHCP range (192.168.1.2-99).
Save those settings and maybe reboot the PC and PS5 to make sure they're getting their new IP, then let us know if you're still having the issue.
