dvnarellano
Mar 28, 2022Aspirant
XR300 Disconnects From Online Games Exactly at 2 hours
Nighthawk Pro Gaming Router XR300\ Firmware is up to date Modem: Netgear CM1000 PC and PS5 Hello, I am reaching out in hopes that someone can propose a solution for my problem. Anytime I a...
Netduma-Fraser
Mar 29, 2022NetDuma Partner
Thanks for all the information, it's very helpful! Is it any particular games you notice it happen in or is it any game? Could you provide the log from the System Information page when the issue happens and tell us the time it happened? Hopefully there will be an entry in there that we can attribute to the issue
dvnarellano
Mar 29, 2022Aspirant
1) I only play two games. One is warzone on PC and the other is FIFA on my PS5. This issue is consistent on both devices and both games.
2) Here is the recent logs. I started playing at 1306 and got disconnected at 1504
[Remote login] from source , Tuesday, Mar 29,2022 15:07:24
[Remote login] from source , Tuesday, Mar 29,2022 15:06:52
[Remote login] from source , Tuesday, Mar 29,2022 15:06:42
[DHCP IP: (192.168.1.10)] to MAC address AE:08:7D:F4:5B:AC, Tuesday, Mar 29,2022 15:04:28
[LAN access from remote] from 24.117.24.209:3074 to 192.168.1.7:3074, Tuesday, Mar 29,2022 13:06:21
[LAN access from remote] from 185.34.107.129:3075 to 192.168.1.7:3074, Tuesday, Mar 29,2022 13:01:39
[Time synchronized with NTP server] Tuesday, Mar 29,2022 12:44:32
[Internet connected] IP address: 68.7.43.253, Tuesday, Mar 29,2022 12:44:32
[DHCP IP: (192.168.1.2)] to MAC address 58:D9:D5:E7:1C:BD, Tuesday, Mar 29,2022 12:29:17
[Remote login] from source , Tuesday, Mar 29,2022 12:09:20
[Remote login] from source , Tuesday, Mar 29,2022 12:08:49
[Remote login] from source , Tuesday, Mar 29,2022 12:08:18
[Remote login] from source , Tuesday, Mar 29,2022 12:07:45
[Remote login] from source , Tuesday, Mar 29,2022 12:07:31
[DHCP IP: (192.168.1.9)] to MAC address E2:CF:97:AC:81:8B, Tuesday, Mar 29,2022 12:01:07
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Mar 29,2022 10:39:24
[DHCP IP: (192.168.1.6)] to MAC address 26:12:FD:8D:99:1A, Tuesday, Mar 29,2022 10:31:19
[DHCP IP: (192.168.1.8)] to MAC address D6:8A:D1:07:69:72, Tuesday, Mar 29,2022 10:24:33
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Mar 29,2022 10:16:58
[LAN access from remote] from 185.34.107.129:3075 to 192.168.1.7:3074, Tuesday, Mar 29,2022 10:14:10
[UPnP set event: Public_UPNP_C3] from source 192.168.1.7, Tuesday, Mar 29,2022 10:14:07
[Remote login] from source , Tuesday, Mar 29,2022 10:08:02
[Remote login] from source , Tuesday, Mar 29,2022 10:01:42
[Remote login] from source , Tuesday, Mar 29,2022 10:01:12
[Remote login] from source , Tuesday, Mar 29,2022 10:01:00
[Remote login] from source , Tuesday, Mar 29,2022 10:00:50
[DHCP IP: (192.168.1.7)] to MAC address 18:C0:4D:0D:80:77, Tuesday, Mar 29,2022 10:00:13
[DHCP IP: (192.168.1.4)] to MAC address A0:78:17:88:E4:0C, Tuesday, Mar 29,2022 09:36:50
[DHCP IP: (192.168.1.6)] to MAC address 26:12:FD:8D:99:1A, Tuesday, Mar 29,2022 08:48:07
[DHCP IP: (192.168.1.5)] to MAC address D6:8A:D1:07:69:72, Tuesday, Mar 29,2022 00:45:31
[DHCP IP: (192.168.1.4)] to MAC address A0:78:17:88:E4:0C, Tuesday, Mar 29,2022 00:45:07
[Internet connected] IP address: 68.7.43.253, Tuesday, Mar 29,2022 00:44:32
[Time synchronized with NTP server] Tuesday, Mar 29,2022 00:44:31
[DHCP IP: (192.168.1.3)] to MAC address A0:CC:2B:AA:52:D0, Tuesday, Aug 08,2023 02:57:52
[DHCP IP: (192.168.1.2)] to MAC address 58:D9:D5:E7:1C:BD, Tuesday, Aug 08,2023 02:57:10
[Internet disconnected] Tuesday, Aug 08,2023 02:57:09
[Initialized, firmware version: V1.0.3.72_10.3.55] Tuesday, Aug 08,2023 02:57:03
- Netduma-LiamMar 30, 2022NetDuma Partner
Could you please go to the XR Settings -> Setup -> LAN Setup and change the DHCP starting IP address to 192.168.1.100.
Then, add IP address reservations for both your PC and your PS5. Make sure you reserve them IP addresses that are outside of the DHCP range (192.168.1.2-99).
Save those settings and maybe reboot the PC and PS5 to make sure they're getting their new IP, then let us know if you're still having the issue.
- dvnarellanoMar 30, 2022Aspirant
Thank you for your help, I am going to apply these changes. Just one question (sorry for my confusion), when you say "outside" the range, the range is currently 192.168.1.100 - 192.168.1.254, so I should go below 100 or above 254 correct? I'm pretty sure that's what you meant, but I am trying to clarify to make sure I don't screw it up on my end and report back with negative results. Thank you again for all your help.
- Netduma-FraserMar 30, 2022NetDuma PartnerYou can't go above 254 so yes below 100 would make it outside the range, let us know how you get on!
