BlazingA
Jul 16, 2020Aspirant
XR300 download speed
So Lately I've noticed that a while ago, my internet speeds were going slower and slower... Before I upgraded my internet plan to a faster speed, the problem also occured to me that I was having such...
Netduma-Fraser
Jul 16, 2020NetDuma Partner
I'd recommend you do a factory reset and go through the setup wizard, that will also do a speed test for your new connection and enter it into the QoS settings. From there you should be able to receive full speeds from a wired PC.
- BlazingAJul 16, 2020Aspirant
I have done the factory reset but I'm still getting the same low download speeds
- Netduma-FraserJul 16, 2020NetDuma PartnerWhat is your exact physical setup? Do you get higher speeds through 5GHz WiFi?
- BlazingAJul 16, 2020AspirantI'm currently doing this with a weird connection although some are wifi, cat7 ethernet cable but I also have a cat6, and after i did the factory reset, it didn't get better but the same results. Also, I've put the same MAC address from the previous router as well and I wasn't giving me internet but I did set it back to default. I'm lost now
