BlazingA
Jul 16, 2020Aspirant
XR300 download speed
So Lately I've noticed that a while ago, my internet speeds were going slower and slower... Before I upgraded my internet plan to a faster speed, the problem also occured to me that I was having such...
BlazingA
I have done the factory reset but I'm still getting the same low download speeds
Netduma-Fraser
Jul 16, 2020NetDuma Partner
What is your exact physical setup? Do you get higher speeds through 5GHz WiFi?
- BlazingAJul 16, 2020AspirantI'm currently doing this with a weird connection although some are wifi, cat7 ethernet cable but I also have a cat6, and after i did the factory reset, it didn't get better but the same results. Also, I've put the same MAC address from the previous router as well and I wasn't giving me internet but I did set it back to default. I'm lost now
- Netduma-FraserJul 16, 2020NetDuma PartnerWhat is the XR plugged into exactly? Are you using a router/modem? Do you require PPPoE/VLAN etc?
- BlazingAJul 16, 2020AspirantIt's plugged into a modem and I did everything else automatically not manually so I haven't messed with it
