Jordoncue
Apr 26, 2021Guide
Xr300 drops my callof duty connection about every hour
It seems like every hour my connection drops and I get the disconnected from blizzards servers. I have done just about everything I've seen, to include reseting router and reinstalling windows. My pc...
Netduma-Liam
Apr 26, 2021NetDuma Partner
Sorry to hear that, thank you for the information!
Could you please answer the below questions:
Do you get the same connection issue when you're not playing CoD?
Does your entire connection drop or is it just a disconnection from the Blizzard servers?
Is your NAT type open in game?
Are you using Geo-filter? If so, how do you have it configured? Are any 'blocked' icons appearing on the map while you're playing?
What firmware version are you currently running on the XR300? It's always worth making sure you're up to date.
