Jordoncue
Apr 26, 2021Guide
Xr300 drops my callof duty connection about every hour
It seems like every hour my connection drops and I get the disconnected from blizzards servers. I have done just about everything I've seen, to include reseting router and reinstalling windows. My pc...
Netduma-Liam
Apr 26, 2021NetDuma Partner
Sorry to hear that, thank you for the information!
Could you please answer the below questions:
Do you get the same connection issue when you're not playing CoD?
Does your entire connection drop or is it just a disconnection from the Blizzard servers?
Is your NAT type open in game?
Are you using Geo-filter? If so, how do you have it configured? Are any 'blocked' icons appearing on the map while you're playing?
What firmware version are you currently running on the XR300? It's always worth making sure you're up to date.
Jordoncue
Apr 26, 2021Guide
So I'm not using Geo filter. My NAT is usually open. Actually I don't think it has been moderate or strict in a long time. And yes it only happens with the blizzard servers. I can play other games such as Arma 3 all night long and never disconnect. I haven't seen any blocked icons, and the firmware is the latest.
Note: I just purchased a xr1000 (like 10 minutes ago on the net gear site) I'm going to see if this solves my problems. However in the meantime I'm going to still try and solve my issues.
- JordoncueApr 26, 2021GuideHere is my modem
Arcadyan CM4652442 - eMTA MoCA 2.0
I'm through mediacom. I also have a 1gig down and 100 up- plemansApr 26, 2021Guru - Experienced User
Looks like that device is a modem/router/moca capable combo device.
it has its own qos/routing capabilities.
Is it in passthrough/modem only mode?
Or the netgears IP address entered into the arcadyan's DMZ?
Do the drops happen if you're directly connected to it?
- JordoncueApr 26, 2021GuideIt's in passthrough. Or as mediacom likes to call it baseline.
