namredik
May 18, 2022Aspirant
XR300 firmware v1.0.3.72 issues
Hello I have been having connection issues every single day since I updated my router to firmware 1.0.3.72. Every time I get connection problems I must reboot it, sometimes twice a day. The ...
Netduma-Liam
May 18, 2022NetDuma Partner
Can you explain what the 'connection problems' are exactly? How do they manifest?
Are you able to access the DumaOS interface when they occur? You can do this by going to 192.168.1.1 in your web browser.
namredik
connection problems like internet interruption and followed by wifi connection lost.
This happens on all my devices. It is not the ISP modem. I have checked that the first time it happened.
I have factory restored the router settings by default several times, same with rebooting it.
The configuration in the router is the basic one, no VPN and QOS activated (default option).
- Netduma-LiamMay 19, 2022NetDuma Partner
- namredikMay 19, 2022Aspirant
yes, i can access it. The only weird thing i have noticed is when this happens the site asks me for the user and password several times in a row
- Netduma-FraserMay 19, 2022NetDuma PartnerWhat web browser/device are you using when you're trying to access the interface?
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
