darkakanthar1
Jun 08, 2020Aspirant
xr300 gaming router
i rebooted my gaming router and now it wont let me click internet setup and it cant detect my ip address its 0.0.0.0.0.0 so on :/
Netduma-Fraser
Jun 09, 2020NetDuma Partner
It looks like you've probably put it in AP mode. Go to the router mode option and switch it back to router mode, everything should work after that has applied.
darkakanthar1
Jun 09, 2020Aspirant
so i should never put on ap mode? also it works now thanks
- Netduma-FraserJun 10, 2020NetDuma PartnerIf you put it in AP mode then you will lose all the features that makes it a good router and will just be using it for pure WiFi so I wouldn't recommend it.
