peterhug
Dec 21, 2022Tutor
XR300 Gaming router
The XR300 currently piggybacks off another router which is configured as a bridge and connected to the modem. I want to remove that router and connect the XR300 directly to the modem. My problem is t...
Dec 22, 2022Guru - Experienced User
I've frequently seen where people are on different subnets and so can't access certain devices.
If the xr300 is in router mode, disconnect it from its current modem (and disconnect the other devices connected).
reboot it and then connect a pc/laptop to it. then see what IP address you get from it and try access it with that.
or using the routerlogin . com
- peterhugDec 22, 2022TutorThe XR300 is connected to a Huawei router (LAN port to LAN port). The XR300 routers IP address in this configuration is 192.168.1.66/24. The Huawei routers address is 192.168.1.254/24. Using a web browser, I can access the Huawei router UI from a laptop connected to a LAN port on the Huawei router, but accessing the XR300 UI times out. If I plug in the laptop on a LAN port on the XR300, it won't connect at all. The same applies if I connect to the XR300 via wifi from my android phone. If I disconnect the XR300 from the Huawei router, the laptop connects and the XR300's IP address changes to 10.0.0.1. The XR300 UI just shows an initial setup screen.
I too think it could be a problem with subnets, but since I can't get to the XR300 UI in the current configuration, I'm in the dark.- Netduma-FraserDec 22, 2022NetDuma PartnerThe XR300 should be connected to the Huawei from its WAN port not LAN port so Huawei LAN > XR300 WAN that should resolve the issues.
- peterhugDec 29, 2022TutorI did try that, but even though the Huawai router is connected to the Internet and the DHCP service is working fine and it is configured properly, the internet port light on the XR300 lights up orange when I connect it to the Huawei router and none of the options I have to setup the Internet connection on the XR300 seem to be right (I was looking for LAN or WAN).
Anyway, I decided to take the risk and remove the Huawai router. Glad to say that everything went well and all the network issues I encountered before are a thing of the past.
Many thanks for all the help from anyone why contributed here.
