Lukespooner
Dec 13, 2019Tutor
Xr300 geo filter and other problems
Right so i have an xr300 the problems are im constantly getting connected outside of my radius and yes everything is setup exaclly how netdumaos tells you to set up i followed all instructions i leave...
Lukespooner
Dec 13, 2019Tutor
Netduma_Alex
Dec 13, 2019NetDuma Partner
In the second screenshot you posted, I can see that there's an icon to the right of the radius. This icon (inside a triangle) represents a blocked server, so if these are the icons you're seeing outside of your radius, it's all working normally.
The appearence of the word "nil" all over the place is actually a known bug. Could you let me know what firmware version you're on?
As a test, could you open a private tab in your browser and see if the nil bug is still present?
- LukespoonerDec 13, 2019TutorHi net duma alex .. as the host marked in the triangle is a blocked connection inside my radius it never shows anyone that i can click on to see the ping etc etc no one is ever shown inside my radius is there a setting i need to have it on to see this ? Also if it is working correctly how come when i have done certain tests it still finds games very easily even in a 50 mile radius it still finds games when i load into bo4 blackout it may be blocking certain hosts as you say no it never shows the host inside my radius for me to ping
I am on the latest firmware i updated the other day to the latest one the nil bug has been there since i purchased the router .. thanks for the help- Netduma-FraserDec 14, 2019NetDuma PartnerCould you provide a screenshot with the map zoomed out completely showing us what it shows when you get a game outside your radius that would be really helpful for us to see what is actually happening as from the screenshot so far it looks like that server is blocked correctly.
- LukespoonerDec 14, 2019Tutor
Hi net duma fraser when i am in a game or trying to find a game in blackout or bo4 i never connect to anyone in the uk its like nobody in the uk is around also sometimes when i do get in games in the radius there is no one to click on to check the ping its just invisible nothing inside the radius at all
