Lukespooner
Feb 14, 2020Tutor
Xr300 geofilter crashing
Hi guys everytime i go to my geofilter in google chrome it just freezes and wont open then locks up my entire browser ? Everything else works fine all the settings qos etc etc but when i click on geof...
Netduma_Alex
Feb 17, 2020NetDuma Partner
Could you try loading up the Geo-Filter in an Incognito tab or in another browser? I wonder if this is a caching issue.
If that works, you should clear the cache in your Chrome browser, that should fix it permanently.
- LukespoonerFeb 17, 2020TutorHi net duma alex ive tried loading it up in the normal browser aswell and it locks up and freezes the same ill try and delete all the cache etc from chrome browser and run it again to see if it works
- Netduma-FraserFeb 18, 2020NetDuma PartnerIf this is still an issue when the page stops responding could you right click on the page and go to Inspect Element > Console tab on the window that appears and take a screenshot please? That will help us determine what caused the issue, you should be able to either reboot or reset the router to fix the issue.
- LukespoonerFeb 21, 2020Tutor
I have rebooted and reset the router this solved nothing it still keeps crashing
