YD58
Mar 24, 2022Aspirant
XR300 Geofilter not working as expected
Hi all, I am trying to use the geofilter on xr300. Obviously a bit tricky to understand as most things just say nil instead of an actual name for setting. I have tried to follow guides here to se...
YD58
Mar 26, 2022Aspirant
Hi, thanks for suggestion but no change in behaviour. I am going to pick up an xr500 today to try out so maybe that will work.
Netduma-Fraser
Mar 26, 2022NetDuma Partner
Did you change the PC to a PlayStation so when you add it back to the Geo-Filter it adds with the console service? As that will filter better. Let us know how you get on!
- YD58Mar 26, 2022Aspirant
Yeah I did try this. Even set as console it still connects to servers outside the set radius.
- Netduma-FraserMar 26, 2022NetDuma PartnerFrom your screenshot it does appear to be blocked outside the radius but Auto Ping thinks it is the host which is odd. In Settings > WAN, can you toggle the NAT option from however it is set now and try again please?
