arithor
Jun 03, 2020Aspirant
XR300 give DHCP to MAC address again again
I have XR300 and his DHCP give me lots of error in monitor LOG I see he give in loop again again in five sec my network new IP and not the same even it is same MAC and if you look and time ...
Netduma-Fraser
Jun 03, 2020NetDuma Partner
Give that device a reserved IP in LAN Settings and shouldn't be a problem. What do you get with QoS disabled in the Anti-Bufferbloat option menu?
arithor
Well Device should only have IP from DHCP when it start
Not in evrey 20 sec ?
Anti Bufferbload is NEWER
Download upload is 1000mb (100%)
Share Exess is X share exxess bandwith all device
ari Thor
- Netduma-FraserJun 03, 2020NetDuma PartnerIt's something we're aware of, meanwhile reserved IP should help. On the Anti-Bufferbloat panel, click the 3 horizontal lines in the top left hand corner of the panel and check the tickbox to disable QoS - do you get higher speeds there?
- arithorJun 07, 2020Aspirant
Hi
I have now Speed at speedtest.net 504 Mbps /455 Mbps 1 ms
If I connect my pc direct to fiber router I get 985/989 Mbps and 1 ms and test to same server by speedtest.netIf I use router where my provider like to rent to me I get also just under 1 Gbps both direction so 500 is good but 995 is much better
If I use FW 1.0.3.38 and restart router to default factory I get speed more sround 250Mbps
So is this 1 Gbps router ?- Netduma-FraserJun 09, 2020NetDuma PartnerIt is a 1g router, is that with traffic meter on or off?
