arithor
Jun 03, 2020Aspirant
XR300 give DHCP to MAC address again again
I have XR300 and his DHCP give me lots of error in monitor LOG I see he give in loop again again in five sec my network new IP and not the same even it is same MAC and if you look and time ...
arithor
Jun 07, 2020Aspirant
Hi
I have now Speed at speedtest.net 504 Mbps /455 Mbps 1 ms
If I connect my pc direct to fiber router I get 985/989 Mbps and 1 ms and test to same server by speedtest.net
If I use router where my provider like to rent to me I get also just under 1 Gbps both direction so 500 is good but 995 is much better
If I use FW 1.0.3.38 and restart router to default factory I get speed more sround 250Mbps
So is this 1 Gbps router ?
Netduma-Fraser
Jun 09, 2020NetDuma Partner
It is a 1g router, is that with traffic meter on or off?
- arithorJun 09, 2020Aspirant
Hi
Traffic meter is OFF
If I turn him on my speed test will go under 100Kbps
So This is not 1g router with traffic meter on. nearly 100 Mbps with meter on
If I test same fiber and same lan cable EdgerRouter X and turn on the default firewallI have speed test to same server 960 to 980 Mbps
XR-300 450 to 520MbpsIs XR-300 a real 1G router ?
- Netduma-FraserJun 09, 2020NetDuma PartnerThe faster speed above is that with QoS completely disabled in the Anti-Bufferbloat menu as mentioned before? It is.
- arithorJun 10, 2020Aspirant
Hi
you are right
I have disable compleate QoS , traffic mesure off and lan direct
I can´t think of more items I can take off
