jreile
Jan 03, 2022Aspirant
XR300 High CPU Usage
Does anyone have issues with high CPU usage for both CPUs on their XR 300 router? I can’t even load the QOS page because the CPU usage is so high. I’ve factory reset the router and there are no availa...
Netduma-Fraser
Jan 04, 2022NetDuma Partner
When did this start to occur? Is the network being maxed out, e.g. downloads consistently?
jreile
Jan 12, 2022Aspirant
It is on 1.0.3.56_10.3.41 which i believe is the current latest version
- Netduma-FraserJan 12, 2022NetDuma PartnerWhen did this start to occur? Is the network being maxed out, e.g. downloads consistently?
