hotpeppershrmp
Jul 19, 2022Aspirant
XR300 is not fully utilizing 500Mb internet speed
I'm using a 500Mb Internet line. Recently, the internet speed was as low as 80Mb, so the speed of the XR300 was restored after factory initialization Today, there is a phenomenon that the speed...
Jul 19, 2022Guru - Experienced User
What is the CAT# LAN cable between the modem/ont and the XR router? CAT6 is recommended.
Speed testing with a wired PC?
- hotpeppershrmpJul 19, 2022Aspirant
Firmware version: XR300 1.0.3.72_10.3.55
The router is connected directly from the port in my room, not via a router from a separate Internet company.
All cables are Cat6.- Netduma-FraserJul 19, 2022NetDuma Partner
The port from your room will eventually connect to a modem//ONT, what is the model of that? It sounds like not all devices are connected to the router is that right? You don't need port forwarding in addition to the NAT open option.
- hotpeppershrmpJul 21, 2022Aspirant
First, I don't think I fully understand the question. Please excuse me.
I am a Korean user, and when I opened the console box of my apartment, I found that it was connected to the port of each room through the ISP's router.
This router is only used in Korea, so I don't think it will be meaningful to tell you the model name. However, I will write down the spec sheet.
Also, there are two rooms in my house, each of which is connected to a PC through a router that uses Wi-Fi function.
However, only my room is experiencing a slowdown.
CPU
MT7621AT (880Mhz, Duad-Core)
Memory
Flash Memory : 128MB
DDR3 : 256MB
Size
150 x 150 x 38
Power
12V/2A
Interface
WAN 10/100/1000M 1 Port
LAN 10/100/1000M 4 Port
USB 2.0 1 Port
Performance
1000Mbps Full Wire-speed
1,024 US/DS NAT Session
1000Mbps NAT Speed
Wireless 802.11a/b/g/n/ac, wave2
Function
Gateway
Network Address Translation(H/W NAT)
Dynamic Host Configuration Protocol(DHCP)
DMZ
VLAN
Port Forwarding
IGMP Proxy(V1,V2,V3)
Application Level Gateway(ALG)
IPv4/IPv6 (Dual Stack)
Firewall
Wireless LAN
802.11a/b/g/n/ac
WMM(Wi-Fi Multi Media) Wireless QoS
Multiple SSID
Qos
Access Control List(ACL)
802.1p/DSCP/ToS/CoS Marking
Priority Scheduling
L2/L3/L4 Classification/Filtering
Security
64bit/128bit WEP Encryption
WPA/WPA2 (TKIP, AES-CCMP)
Prevent Malicious Packet Strom Control
