jgkhgk
Feb 24, 2022Tutor
XR300 Keeps Rebooting
Good afternoon, My router keeps rebooting every couple of hours and sometimes minutes. i lose all connection both wifi and ethernet. The router turns off all the white lights except this amber ligh...
Netduma-Liam
Feb 25, 2022NetDuma Partner
The first thing to do would be to upgrade to the latest firmware and then factory reset the XR300 afterwards. Let us know if you're still experiencing this issue afterwards.
https://kb.netgear.com/000064602/XR300-Firmware-Version-1-0-3-72
- jgkhgkFeb 25, 2022Tutor
i applied the method suggested so im going to give it like an hour
- jgkhgkMar 02, 2022Tutor
So the router was back up and running when i factory reset it but now its back to rebooting into the amber light again. it was fine for about two days.
- Netduma-LiamMar 03, 2022NetDuma Partner
Could you please try changing the DHCP range to start from .50, then reserve IP addresses for devices that are disconnecting from .2 to .49. Such that devices on your network have IP addresses outside of the DHCP pool.
After that, reboot the router from the interface and see if you're still having the same issue.
