jgkhgk
Feb 24, 2022Tutor
XR300 Keeps Rebooting
Good afternoon, My router keeps rebooting every couple of hours and sometimes minutes. i lose all connection both wifi and ethernet. The router turns off all the white lights except this amber ligh...
Netduma-Liam
Mar 03, 2022NetDuma Partner
Could you please try changing the DHCP range to start from .50, then reserve IP addresses for devices that are disconnecting from .2 to .49. Such that devices on your network have IP addresses outside of the DHCP pool.
After that, reboot the router from the interface and see if you're still having the same issue.
jgkhgk
Mar 03, 2022Tutor
how would i go about doing this in dumaos?
- Netduma-FraserMar 03, 2022NetDuma PartnerOn the interface go to Settings > LAN Settings and you can do so from there
- jgkhgkMar 03, 2022Tutor
The only option i was able to find was this on settings. i apologize for the little red censor im not sure wether or not tha should be private.
- Netduma-LiamMar 04, 2022NetDuma Partner
Change the 'Starting IP address' to be 192.168.1.50.
Then, under setup -> LAN Setup, reserve IP addresses for each device. Make sure the address you give them is between .2 and .49.
