weedminer
Jan 25, 2021Aspirant
XR300 losing 50% of speed when bridging
Hello, When I use the following option to get my IPTV working, the IPTV works perfectly, but the internet speeds are 40-50% worse. If I untick Enable VLAN Bridge Setup, it goes ba...
- Jan 26, 2021Check with Geo disabled and see if you have any connection issues - namely the ability to connect to players.
Netduma-Liam
Jan 26, 2021NetDuma Partner
Sorry to hear you're having these troubles!
So are you losing bandwidth over both wired and wireless?
Have you disabled anything else in DumaOS such as Geo-filter etc to make sure it's not a Rapp affecting things?
- weedminerJan 26, 2021Aspirant
Both wired and wireless, it's the same.
I have removed Geo-filter, QoS, enabled disabled settings like UPNP, port scan and dos protection, nat-filtering, igmp proxying.
Nothing helped.
I also tried 3 different OS firmware versions and factory reset the router at least 3 times already.- Netduma-FraserJan 26, 2021NetDuma PartnerHey weedminer I remember we've discussed this on the Netduma forum, I doubt any NG staff will comment here but hopefully some other users may help, is your workaround still working?
Hey Netduma-Fraser ,
It doesn't because it introduces a NAT type issue, from having the switch before everything.
I only posted here because I wanted Netgear staff involved.
Does it seem like this won't be solved, I am confused? I need to somehow make this work.
