weedminer's avatar
weedminer
XR300 losing 50% of speed when bridging
Hello,   When I use the following option to get my IPTV working, the IPTV works perfectly, but the internet speeds are 40-50% worse.       If I untick Enable VLAN Bridge Setup, it goes ba...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jan 26, 2021
    Check with Geo disabled and see if you have any connection issues - namely the ability to connect to players.
