DevilsBlubber
May 29, 2023Guide
XR300 Nighthawk throttling speeds
Hello, the past few months I have been having issues with my Nighthawk xr300. Seemingly at random my wifi and ethernet connection speeds will drop from 350mbps to 70-100mbps. Last time I was able to ...
- May 31, 2023
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Netduma-Fraser
May 29, 2023NetDuma Partner
Generally when it throttles it's due to your QoS settings, could you attach a screenshot of your QoS page please?
- DevilsBlubberMay 29, 2023Guide
Here you go, I had the QoS settings on default. But just tried disabling them, no difference so far.
- Netduma-FraserMay 29, 2023NetDuma PartnerIt's still throttling with QoS completely disabled? What is the model of the modem/router the XR is connected to? Are ALL devices connected to the XR?
- DevilsBlubberMay 30, 2023Guide
The XR300 is connected to my ISP modem Model: TM1602A. My computer is connected through ethernet to the XR300, and both my ethernet connection and wifi running off the XR300 seems to be throttled to 100mbps. If I directly connect my PC to the ISP modem there are no issues.
