DevilsBlubber's avatar
May 29, 2023
XR300 Nighthawk throttling speeds
Hello, the past few months I have been having issues with my Nighthawk xr300. Seemingly at random my wifi and ethernet connection speeds will drop from 350mbps to 70-100mbps. Last time I was able to ...
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
