virtuous
Oct 16, 2020Aspirant
XR300 Not Reaching ISP speeds
Hey all, I've recently purchased the Nighthawk XR300, and have recently started using it but I've noticed that the speeds aren't reaching my expected ISP speeds, 1000mbps. I read on the website speci...
Netduma-Fraser
Oct 16, 2020NetDuma Partner
Have you entered your expected speeds into bandwidth settings? What are your QoS settings? What is your exact physical setup?
virtuous
Oct 17, 2020Aspirant
I'm not sure what you mean by physical setup, but I'll tell you what I know. I have a 1000MBPS NBN Fibre plan, router is plugged directly into the wall's nbn port from the WAN port. I access my internet through wifi on my devices, no ethernet. QoS settings are disabled, and I'm not sure how to access the bandwidth settings.
- Netduma-FraserOct 17, 2020NetDuma PartnerDo you have a modem/router provided by NBN? In the Congestion Control 3 line option menu you can enter your speeds that you expect, have you done this?
- virtuousOct 17, 2020Aspirant
Congestion Line 3..? I'm sorry, I don't know where to find this.
Netduma-Fraser wrote:
Do you have a modem/router provided by NBN? In the Congestion Control 3 line option menu you can enter your speeds that you expect, have you done this?- Netduma-FraserOct 18, 2020NetDuma PartnerOn the QoS Page, on the Congestion Control panel, in the top left hand corner of that panel is a 3 horizontal line symbol which symbolized a menu/settings for that individual panel, click that.
